XSlashDashX's avatar
Feb 07, 2019
Just purchased XR700
Hello! I've just got in the mail the XR700 model Netgear and this thing is sweet looking, (haha)
Anyways my hardline to PC is getting full speed. My package is 400/20.
Now when I try to do wifi over ps4 i'm only seeing like 44/50 down and other times will be 160/190 down. I can put my phone next to the ps4 and do speed test and get achieve almost 400 down on my phone connected to wifi. I haven't messed with settings much since I've only owned the device for couple hours. Just seeing what yall opinions are right now. I do have 2.4 and 5ghz on and not set to auto. I believe I turned off QoS. I will probably play with the settings more and see what I can get out of. Been watching John Glasscock I think his name on YouTube. I think he has some pointers I need to try.
  • FURRYe38's avatar
    I wouldn't be too confident in game console wifi adapters. Can be very flaky.
    Gaming consoles are preferred to be wired.
    If wired speeds are good and a mobile device speeds are good as well. Then wireless should be fine.
    • Netduma_Jack's avatar
      Netduma_Jack
      NetDuma Partner
      As Furry said, it's probably the quality of the Wifi chip in the device you're testing with. If wired speeds are good, and wireless speeds are maxed out on devices with great WiFi chips, like mobile phones, then all signs point to it just being the quality of the wireless on the device you're testing with.
      • XSlashDashX's avatar
        XSlashDashX
        Tutor
        Gotcha! I'll keep that in mind when I get off work and mess with the XR700 some more. But so far so good.
