egwok
Mar 24, 2023Tutor
Just recently xr1000 help
My xr 1000 is just recently having this issue with my upNp can anyone tell me how to fix it ? Attached photo is my Xbox series x ip (192.168.1.2 ) the 192.168.1. 16 i don’t know what device it is sin...
- Mar 24, 2023
There is a wifi button on top of the router that you can press for 5 seconds then release that will turn OFF the wifi radios. Pressing this again for 5 seconds then release will turn them back ON.
Mar 24, 2023Guru - Experienced User
You need to find out what device is connected to your router that's using .16.
How is the xbox connected? Wired is preferred.
I'd set up a IP address reservation as well for the xbox.
Start by disabling WiFi radios on the router to see if the .16 device disappears.
- egwokMar 24, 2023TutorI’m wired on Xbox and I’ll give it a try . And I already have the Xbox ip reserved . But I’m gonna try the WiFi thing when I looked at my manage devices I seen a lot WiFi devices connected too many to all be mine ? Could I been hacked by hacker? I’d so how can I get the hacker off my router? Factory reset will get the hacker off?
- Netduma-FraserMar 24, 2023NetDuma PartnerIt's unlikely to be a hacker, just a device that doesn't have a name on the Device Manager, check your devices themselves to see what their IP is and match it
- egwokMar 24, 2023TutorSo do I disable the WiFi cause I don’t see no where to disable WiFi also thanks for your help .
