egwok
Mar 24, 2023Tutor
Just recently xr1000 help
My xr 1000 is just recently having this issue with my upNp can anyone tell me how to fix it ? Attached photo is my Xbox series x ip (192.168.1.2 ) the 192.168.1. 16 i don’t know what device it is sin...
- Mar 24, 2023
There is a wifi button on top of the router that you can press for 5 seconds then release that will turn OFF the wifi radios. Pressing this again for 5 seconds then release will turn them back ON.
Mar 24, 2023Guru - Experienced User
You need to find out what device is connected to your router that's using .16.
How is the xbox connected? Wired is preferred.
I'd set up a IP address reservation as well for the xbox.
Start by disabling WiFi radios on the router to see if the .16 device disappears.
egwok
Mar 24, 2023Tutor
I’m wired on Xbox and I’ll give it a try . And I already have the Xbox ip reserved . But I’m gonna try the WiFi thing when I looked at my manage devices I seen a lot WiFi devices connected too many to all be mine ? Could I been hacked by hacker? I’d so how can I get the hacker off my router? Factory reset will get the hacker off?
- Netduma-FraserMar 24, 2023NetDuma PartnerIt's unlikely to be a hacker, just a device that doesn't have a name on the Device Manager, check your devices themselves to see what their IP is and match it
- egwokMar 24, 2023TutorSo do I disable the WiFi cause I don’t see no where to disable WiFi also thanks for your help .
- FURRYe38Mar 24, 2023Guru - Experienced User
- egwokMar 24, 2023TutorOkay so yeah that fix it now I only got one port on 192.168.1.2 which is port 51332 but isn’t it suppose to be port 3074 for Xbox there ? Sometimes it will show port 3074 but then it just changes back to a random port is that normal ?
- Netduma-FraserMar 24, 2023NetDuma PartnerIf you've identified the device there is no need to disable WiFi. Yes the Xbox uses a variety of ports, if you have an Open NAT you're good.
