egwok
Mar 24, 2023Tutor
Just recently xr1000 help
My xr 1000 is just recently having this issue with my upNp can anyone tell me how to fix it ? Attached photo is my Xbox series x ip (192.168.1.2 ) the 192.168.1. 16 i don’t know what device it is sin...
- Mar 24, 2023
There is a wifi button on top of the router that you can press for 5 seconds then release that will turn OFF the wifi radios. Pressing this again for 5 seconds then release will turn them back ON.
egwok
Mar 24, 2023Tutor
I’m wired on Xbox and I’ll give it a try . And I already have the Xbox ip reserved . But I’m gonna try the WiFi thing when I looked at my manage devices I seen a lot WiFi devices connected too many to all be mine ? Could I been hacked by hacker? I’d so how can I get the hacker off my router? Factory reset will get the hacker off?
Netduma-Fraser
Mar 24, 2023NetDuma Partner
It's unlikely to be a hacker, just a device that doesn't have a name on the Device Manager, check your devices themselves to see what their IP is and match it
- egwokMar 24, 2023TutorSo do I disable the WiFi cause I don’t see no where to disable WiFi also thanks for your help .
- FURRYe38Mar 24, 2023Guru - Experienced User
- egwokMar 24, 2023TutorThanks a lot for your help have a great weekend
- egwokMar 24, 2023TutorOkay so yeah that fix it now I only got one port on 192.168.1.2 which is port 51332 but isn’t it suppose to be port 3074 for Xbox there ? Sometimes it will show port 3074 but then it just changes back to a random port is that normal ?
- Netduma-FraserMar 24, 2023NetDuma PartnerIf you've identified the device there is no need to disable WiFi. Yes the Xbox uses a variety of ports, if you have an Open NAT you're good.
- egwokMar 24, 2023TutorThanks again
