egwok
Mar 24, 2023Tutor
Just recently xr1000 help
My xr 1000 is just recently having this issue with my upNp can anyone tell me how to fix it ? Attached photo is my Xbox series x ip (192.168.1.2 ) the 192.168.1. 16 i don’t know what device it is sin...
- Mar 24, 2023
There is a wifi button on top of the router that you can press for 5 seconds then release that will turn OFF the wifi radios. Pressing this again for 5 seconds then release will turn them back ON.
egwok
Mar 24, 2023Tutor
So do I disable the WiFi cause I don’t see no where to disable WiFi also thanks for your help .
Mar 24, 2023Guru - Experienced User
