JoeFI
Jan 15, 2021Apprentice
Kicked from dashboard
Hi, I keep getting kicked out of my router dashboard with the message I'm signed in from another device and to either continue or exit. The ex770 is on my network also. It has happened about once a m...
Netduma-Fraser
Jan 15, 2021NetDuma Partner
Are you using either the Nighthawk or the DumaOS app at all? Have you left the interface open on any devices - I'm assuming you haven't? Is it on the VPNd device you notice it?
