Netduma_Alex
Sep 12, 2019NetDuma Partner
KNOWN ISSUE: Login problems using latest Chrome version
On the latest version of Chrome (77.0.3865.75) we have identified an issue where users may have trouble logging into their Netgear Nighthawk Pro Gaming router. This affects the XR300, XR450, XR500 an...
- Sep 17, 2019
A workaround for this issue has been found:
Paste the following address into your Chrome address bar and press enter: chrome://flags/#http-auth-committed-interstitials
Change the highlighted setting to Disabled and press Relaunch Now
Now you should be able to log in as normal again
There's a Netgear knowledge base article about it here: https://kb.netgear.com/000061261/Google-Chrome-77-is-blocking-access-to-NETGEAR-login-pages-what-do-I-do
tkevans
Sep 12, 2019Apprentice
Seeing this on my ReadyNAS 204 as well. Running 6.10.2-T49 (Beta 1)
Netduma-Fraser
Must be something Chrome have done with their update, I'm sure a lot of companies will have deploy fixes on their side.
- FURRYe38Sep 12, 2019Guru - Experienced User
Be aware of what Mozilla and Google are going to be doing to there browsers:
https://www.theregister.co.uk/2019/09/10/chrome_78_dnsoverhttps
Not sure if this will be effecting local router log in pages or not.
- Netduma_AlexSep 13, 2019NetDuma Partner
Actually I imagine this might affect the routerlogin.net and dumaos/ methods of router access, thanks for the heads up!
