Netduma_Alex
Sep 12, 2019NetDuma Partner
KNOWN ISSUE: Login problems using latest Chrome version
On the latest version of Chrome (77.0.3865.75) we have identified an issue where users may have trouble logging into their Netgear Nighthawk Pro Gaming router. This affects the XR300, XR450, XR500 an...
- Sep 17, 2019
A workaround for this issue has been found:
Paste the following address into your Chrome address bar and press enter: chrome://flags/#http-auth-committed-interstitials
Change the highlighted setting to Disabled and press Relaunch Now
Now you should be able to log in as normal again
There's a Netgear knowledge base article about it here: https://kb.netgear.com/000061261/Google-Chrome-77-is-blocking-access-to-NETGEAR-login-pages-what-do-I-do
Sep 13, 2019Guru - Experienced User
For people using Chrome v77, other users have said that doing a reboot of the PC fixes how Chrome works with the log in pages.
- tkevansSep 13, 2019Apprentice
FURRYe38 wrote:For people using Chrome v77, other users have said that doing a reboot of the PC fixes how Chrome works with the log in pages.
Not here, it doesn't. (Fedora 30 on both Lenovo T530 laptop and Dell desktop).
- FURRYe38Sep 13, 2019Guru - Experienced User
Linux, not sure how that will play out. Others I believe are Windows users.
- Netduma_AlexSep 17, 2019NetDuma Partner
