Hibachi's avatar
Hibachi
Lag Spikes on Wifi 2.4 & 5 .XR500
Did a regular setup updated the firmware.
Had an issue connecting to 5Ghz "can't connect to this network"
(fixed by forgeting network in network settings and removing password)
Tested speeds Getting: 180 mbps download, 10 mbps upload
Started up game R6S to test out connection
Very bad lag spikes on 2.4 GHz
Occasional lag spikes on 5 GHz
Tried rebooting.
Tried factory reset.
Gonna give this a few days before i return this.
    • Hibachi's avatar
      Hibachi
      Followed the steps
      used the geo filter as directed, and enabled qos
      Nat is Open, ping in game is low, still spiking badly, now i cant connect to the 5g network anymore.
      5ghz was working yesterday
      Was able to connect 5ghz to my pc, iphone, xbox.
      The light is on but the network is not appearing at the moment.
      It appears randomly
      My old r7000 (4-5 years) had the same 5g issue. looked up and found that it might be a windows 10 issue.
       Was able to play on 2.4ghz with no problem no QOS. although 5ghz was more ideal while i had it
      Only frustrating thing is, i hooked up my r7000 and did a regular set up and everything worked perfect. The price of this thing i didnt think I would have any issues on start. But i guess there is still more that needs to be done before its optimal
