joned030
Jan 01, 2019Follower
LAN Connectivity Isues and Poor WiFi signal on XR500
I have recently bought the Nighthawk Pro Gaming router, the XR500, in order to stabilise my internet connection when gaming and in preparation for when I get Sky Fibre installed next Sunday, an upgrad...
Jan 01, 2019Guru - Experienced User
What FW is currently loaded?
What WPA security modes are you using? Try WPA2 and AES only.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
- Netduma_JackJan 02, 2019NetDuma Partner
Really good advice from Furry above.
Ultimately the XR500 has very powerful WiFi so I'm surprised you're not getting a great connection through it. Definitely try a different channel on each of the bands to see if that helps (go to Settings >Wireless Setup to configure this)
