CptnMorgan
Apr 20, 2020Tutor
LAN Ethernet Ports Stop Working
Firmware version 1.0.5.8 Not aware of when the last update was installed. Problem began 4/18/20 Having issues where LAN Ethernet Ports stop working every morning. Nothing on my network has change...
Apr 20, 2020Guru - Experienced User
1. What modem are you using?
2. What firmware are you on? and please give a version and not "the latest"
3. What have you done to try to fix it?
4. You put that it happens every morning. LIke clockwork? is it exactly 24 hours?
5. Is it just the lan ports? wifi still works?
CptnMorgan
Apr 20, 2020Tutor
Thanks for the quick reply but I shouldn't even respond to this reply. Especially since the answer to most of your questions are clearly stated in my original post.
Motorola SB6183 - this has nothing to do with my LAN ports not working. All wifi devices are working fine. You don't need a modem to use a router. This is not an internet problem. It is port access issue.
Yes it is just Ethernet Ports.
Pretty much clockwork. We get on the desktop every morning at about 8am and find it has stopped. I then check connectivity to my NAS which is also disconnected.
looks like my NAS never reestablished connection after it's automatic 5am reboot. That is the most accurate time I can pinpoint.
- plemansApr 20, 2020Guru - Experienced User
CptnMorgan wrote:
Thanks for the quick reply but I shouldn't even respond to this reply. Especially since the answer to most of your questions are clearly stated in my original post.You realize this is members of the public trying to help out for free? We're not netgear.
If you want to have attitude, I'm happy to help someone else. and you answered 2 of the 5 questions I asked.
Thanks and good luck getting it working!
- CptnMorganApr 20, 2020TutorYes I understand I am reaching out to the public and I apologise if I sound ungrateful. But this has obviously been a problem people have been facing for a long time without any apparent resolution through various versions of firmware.
The fact I started the post with the firmware version immediately tells me the post is not being read in its entirety. I deal with this poor communication issue with Co workers and IT support people enough. Don't assume I am just an end user who needs help identifying the power cord for a "reset" please- plemansApr 20, 2020Guru - Experienced User
Ok, I'll give you the firmware the the top. 3/5.
Again good luck. I'd rather help someone who appreciates the fact that I'm trying to help others on MY time.
I'm not going to fight to get details or argue about unappreciative customer services agents.
