Tendrop
Aug 03, 2019Aspirant
LAN Issues and Slow Geo-filter
Despite at least one factory reset, rolling back the firmware and setting static IPs, I continue to have issues with the LAN connections which are direct from router to an xbox one x and a desktop c...
-Donovan-
Aug 03, 2019Luminary
There's a new Hot-Fix you can try here:
https://kb.netgear.com/000061118/XR700-Firmware-Version-1-0-1-18-Hot-Fix
Or you can sign up to the beta program here:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR700-Beta-Firmware/m-p/1760800#M11125
Note: Make sure you perform a factory reset right after you update your firmware.
Tendrop
Thank you for the quick response. Will I need to factory reset with the beta firmware too. Such a pain to reset with a fios modem! Thanks.
- TendropAug 03, 2019Aspirant
No need to reply Donovan. I understand your message now. Thanks again.
- -Donovan-Aug 04, 2019Luminary
Let us know how things goes with the new firmware on your setup.
- TendropAug 04, 2019Aspirant
Thanks for checking with me Donovan. I keep getting "This R-App is not loaded yet, please try again in a minute" error. I factory reset again today with the new FW but keep getting this.
I am ready to RMA this router unless you have a recommendation.
