latinkreationz
Feb 18, 2018Star
LAN Port vs LED Port Light
I just noticed something really wierd with my router. I have LAN ports 1 and 2 being used, yet the LED indicators show I'm using ports 3 and 4. I've never had this happen before. I guess I shouldn...
- Feb 19, 2018No need to worry. Netgear are aware of this so it's my understanding they will be working on a fix.
XRaptor29
Feb 19, 2018Luminary
Yeah, it's backwards on the back of the router. 4-1 should be 1-4 but it's not. The front is right. What they could do is probably adjust the firmware to make 1-1 etc.
I have my Ethernet plugged into 4 and 3 on the back and it shows up as 1 and 2 on the front.
Netduma-Fraser
Feb 19, 2018NetDuma Partner
- latinkreationzFeb 19, 2018Star
Thanks XRaptor29 for confirming I'm not the only one. I did the same thing as well so that 1 and 2 would be lit.
Also, thanks Netduma-Fraser for confirming this will be addressed.
