latinkreationz
Feb 18, 2018Star
LAN Port vs LED Port Light
I just noticed something really wierd with my router. I have LAN ports 1 and 2 being used, yet the LED indicators show I'm using ports 3 and 4. I've never had this happen before. I guess I shouldn...
- Feb 19, 2018No need to worry. Netgear are aware of this so it's my understanding they will be working on a fix.
Netduma-Fraser
Feb 19, 2018NetDuma Partner
latinkreationz
Feb 19, 2018Star
Thanks XRaptor29 for confirming I'm not the only one. I did the same thing as well so that 1 and 2 would be lit.
Also, thanks Netduma-Fraser for confirming this will be addressed.
