latinkreationz
Feb 18, 2018Star
LAN Port vs LED Port Light
I just noticed something really wierd with my router. I have LAN ports 1 and 2 being used, yet the LED indicators show I'm using ports 3 and 4. I've never had this happen before. I guess I shouldn...
- Feb 19, 2018No need to worry. Netgear are aware of this so it's my understanding they will be working on a fix.
Killhippie
Mar 13, 2018Prodigy
It should have not gone though QA like this, a pretty big mistake really. Shm
Killhippie
Mar 16, 2018Prodigy
Looking at the PDF for the XR500 it shows Ethernet port 1 is closest to the WAN port as it should be, not the furthest away as it is on mine and many other XR500's. So that would seem to indicate that the current XR500's or at least some of them have had the port designation printed the wrong way round. Thats a real blunder. I hope Netgear will be replacing those units to those effected. (Thats if this PDF is correct of course)
https://www.download...XR500_UM_EN.pdf
- Netduma-FraserMar 16, 2018NetDuma PartnerThanks for the additional information, all we've been told is that they are looking into it further so I can't comment on that as I don't know either way.
- KillhippieMar 16, 2018Prodigy
That’s a real shame, Fraser. You would think they would’ve managed to work out what they could and couldn’t do with their own hardware by now. I’m sure many people are past their return date as well if it does turn out to be hardware issues, and even if it is cosmetic at that price people deserve to get what they paid for which is a router without port assignment issues. Thanks for letting us know the current situation anyway let’s hope it gets sorted out sooner rather than later as this really shouldn’t of happened in the first place. Take care
