OlegP
Sep 14, 2018Apprentice
Latest 2.3.2.32 firmware cripples the XR500
I’ve only had the XR500 router for about a month. Unfortunately, so far I’m not at all impressed with the main selling feature that is DumaOS and I’m frustruated to the point of potentially exchangin...
- Oct 01, 2018
A quick status update on the issue. I few days ago I replaced the brand new Arris TM1602 modem that I got from Spectrum/Charter last month since I’ve just found out that the Arris modem has that garbage Intel Puma6 chip.
In its place I put an equivalent Netgear CM600 and now I’m running the .32 FW without any speed or MAC address issues; however, I still get WiFi devices disconnect on me for a few seconds when on the 2.4Ghz band.
So the .32 FW issue might have been related to the Arris modem, even though it seems to run fine with the XR500 on the .22 FW version.
Sep 18, 2018Guru - Experienced User
Unknown. They don't say when FW updates are forth coming. Just have to keep an eye on it.
Might try changing to a manual channel on 2.4ghz. Disable MIMO and HT160 as well.
OlegP
Oct 01, 2018Apprentice
- FURRYe38Oct 01, 2018Guru - Experienced User
Might try changing to a manual channel on 2.4ghz. Disable MIMO and HT160 as well. Set WPS2 and AES only...
