beeballinb70
Oct 03, 2019Guide
Lease expires causing internet to disconnect for a few seconds every 24hrs
This started about 5 weeks ago. Lease expires & internet disconnects for a few seconds every 24 hrs, ethernet & wifi. Im stumped, why would this suddenly start happening? I even changed from arris 820...
- Oct 26, 2019I decided to just buy the nighthawk xr700. Zero disconnects & everything is running better than ever.
beeballinb70
Oct 04, 2019Guide
Hmmmm.. i’ve searched under administration countless times on my xr500... I haven’t seen anything that would let me choose a time for the lease. I did release the lease & renew it a few times under connection status.. but that didn’t stop my issue at all.
Ty
Ty
Netduma-Fraser
Oct 05, 2019NetDuma Partner
Could you please give a static/reserved IP to some of your devices to start with and see if they sustain a connection when others don't please?
- beeballinb70Oct 05, 2019GuideWhen i get home I will try a factory reset first. If that doesn’t work. I will try this.
my dad’s xr500 works perfectly with his internet, zero disconnects.. & it is updated current version.
Ty- Netduma-FraserOct 05, 2019NetDuma PartnerCould be a faulty router but we'll have to investigate further. Keep us updated.
- beeballinb70Oct 05, 2019GuideI will
Appreciate all the ideas 💡
