pinkpig83
Dec 06, 2018Follower
LED
What is the difference between a white lamp and an orange lamp?
ETH1 - play station4
ETH2 - PC
sometimes ETH LED color is orange when I play PS4
The game is much more pleasant when the orange LED on ETH1 is on
However, most white LEDs on the ETH-1 light up when playing the Playstation
1 Reply
- Netduma_JackNetDuma Partner
Hi there - it means the bandwidth speed is limited to 100mbps. Either because the device itself cannot go any faster on this, or because you're using an Ethernet cable that is not fast enough e.g. Cat 5 (Cat5e, Cat6 and Cat 7 cables can do 1000mbps)
