Justmitch
Dec 10, 2018Aspirant
limited internet
hi evryone
im not a very with this kind of thing so need some help please .
i have just got the RX500 nighthawk Pro Gaming Router with the DM200 Modem .i have bt internet with is fiber to the gre...
Dec 10, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
- JustmitchDec 10, 2018Aspirant
