Justmitch
Dec 10, 2018Aspirant
limited internet
hi evryone
im not a very with this kind of thing so need some help please .
i have just got the RX500 nighthawk Pro Gaming Router with the DM200 Modem .i have bt internet with is fiber to the gre...
Netduma_Jack
Dec 11, 2018NetDuma Partner
Hi there - first of all, very cool to hear you've been gaming for so long!
Could you try these steps please:
- Try resetting your modem, then rebooting your XR500. Does it obtain an Internet connection after this?
- If not, can you set your modem into bridge mode or modem mode and try again?
- Finally, if that doesn't work, try factory resetting your XR500. Going through the initial setup will allow it to auto-detect your connection type (here's how to factory reset: https://kb.netgear.com/000053098/How-do-I-perform-a-factory-reset-on-my-Nighthawk-Pro-Gaming-router
If that still does now work, I recommend you contact NETGEAR's official support as they may be able to help fix your issue: https://www.netgear.com/support/contact.aspx
- JustmitchDec 11, 2018Aspirant
Thanks for your help .
i have tried all you suggested over the last two days with no luck so with some sadness I have sent them back so I’m open to suggestions to witch router and modem to go with or maybe just router /modem in one box HELP needed lol
yes I have seen such a change in game it over the years and have to say I never believed it would get so big a thing I would love to be around in a few moor years to see where it goes
again thank you for you help
- FURRYe38Dec 11, 2018Guru - Experienced User
What ISP service do you have? DSL or Cable?
Its preferred to have a modem with out any built in router. Just a modem only. Then any external router like a XR will connect and should work well. I have the XR450. Works with my cable modem. Modem only of course.
I have DSL
Its fibre to the green box Which is some way down the road then it copper to my house .
i get a
around 35 /40 mb speed
