Justmitch
Dec 10, 2018Aspirant
limited internet
hi evryone
im not a very with this kind of thing so need some help please .
i have just got the RX500 nighthawk Pro Gaming Router with the DM200 Modem .i have bt internet with is fiber to the gre...
Justmitch
Dec 11, 2018Aspirant
Thanks for your help .
i have tried all you suggested over the last two days with no luck so with some sadness I have sent them back so I’m open to suggestions to witch router and modem to go with or maybe just router /modem in one box HELP needed lol
yes I have seen such a change in game it over the years and have to say I never believed it would get so big a thing I would love to be around in a few moor years to see where it goes
again thank you for you help
Dec 11, 2018Guru - Experienced User
What ISP service do you have? DSL or Cable?
Its preferred to have a modem with out any built in router. Just a modem only. Then any external router like a XR will connect and should work well. I have the XR450. Works with my cable modem. Modem only of course.
- JustmitchDec 11, 2018Aspirant
I have DSL
Its fibre to the green box Which is some way down the road then it copper to my house .
i get a
around 35 /40 mb speed
- FURRYe38Dec 11, 2018Guru - Experienced User
I would ask your ISP about what modems are supported on there system. Ask them about a modem only option. If they have one or you can find it as a retail unit that you can buy, try this. Then go for a external router, you can try the XR routers again. If they only seem to support modem router combo units, then you'll have to try one and use the DMZ on the modem for any external router that you connect to it. Disable any wifi on the modem as well.
