xiimagzx
Oct 21, 2020Guide
(logs) Internet going out once a day
Every day I get one time where the internet comes in and out, Ive talked to my isp they said its not from them and it might be due to something with the firewall in the router setting off the dos att...
- Oct 28, 2020
FOUND THE SOLUTION turn off ddos protection on the router it was giving false reports and causing a issue. I'm haven't had a problem since my last comment on the thread! and that's unheard of before I would have had at least once a day now none!
xiimagzx
Oct 22, 2020Guide
The net goes down once a day but on the router it's self doesn't say so(no amber led on router), so I think its like a bunch of packet miss fires causing me to disconnect from discord on my second pc and also lag out the game of cod on the gaming pc. I don't know if it happens to wireless wifi due to me using ethernet when it happens on both pcs. I also for got to say i have a s8000 plugged into the router for more ethernet ports
Netduma-Fraser
Oct 22, 2020NetDuma Partner
What is your exact physical setup? I.e. what is the XR connected to - is it a modem/router or just a modem?
- xiimagzxOct 22, 2020Guide
Fiber thing in wall -> xr500 -> s8000 -> my pc's and brothers ps4 and pc
also side not i did not do any of the lines in the log so the del and add command for upnp was not me- Netduma-FraserOct 22, 2020NetDuma PartnerIs fiber thing in the wall a box or an ethernet cable from the wall? Give some of your devices that you notice the issue on the most a reserved IP in LAN Settings and see if that helps.
