xiimagzx
Oct 21, 2020Guide
(logs) Internet going out once a day
Every day I get one time where the internet comes in and out, Ive talked to my isp they said its not from them and it might be due to something with the firewall in the router setting off the dos att...
- Oct 28, 2020
FOUND THE SOLUTION turn off ddos protection on the router it was giving false reports and causing a issue. I'm haven't had a problem since my last comment on the thread! and that's unheard of before I would have had at least once a day now none!
Netduma-Fraser
Oct 23, 2020NetDuma Partner
Are you on the very latest firmware .44?
Mi6300m
Oct 23, 2020Aspirant
I am yes. When I first got mine around Oct 4th it downloaded and installed that update on initial setup.
- Netduma-FraserOct 23, 2020NetDuma PartnerGive your devices reserved IPs in LAN settings and see if that helps please.
- Mi6300mOct 23, 2020Aspirant
I can definitely say that won't help. That's normally how I configure my routers. I commonly do this since I actually keep an eye on what's using the most bandwidth in the house (old days before discovering DumaOS).
- Netduma-FraserOct 23, 2020NetDuma PartnerCould you post the log file you get around the time that you experience a disconnection please?
