xiimagzx
Oct 21, 2020Guide
(logs) Internet going out once a day
Every day I get one time where the internet comes in and out, Ive talked to my isp they said its not from them and it might be due to something with the firewall in the router setting off the dos att...
- Oct 28, 2020
FOUND THE SOLUTION turn off ddos protection on the router it was giving false reports and causing a issue. I'm haven't had a problem since my last comment on the thread! and that's unheard of before I would have had at least once a day now none!
Netduma-Fraser
Oct 28, 2020NetDuma Partner
I have sent you a Private Message, please check there.
xiimagzx
Oct 28, 2020Guide
