user41018
Mar 05, 2022Aspirant
Looking for a router with DumaOS
Hello, I'm looking for a router with DumaOS, The only one I've found was the XR500. Which others have DumaOS and do all have the version 3.0?
Netduma-Fraser
Mar 06, 2022NetDuma Partner
Great to hear that, based on your setup that would be what I would suggest as well so you'll get the stability and range the TP WiFi gives you while benefiting from the R2 features.
user41018
Mar 06, 2022Aspirant
Ok thanks, so it's actually beneficial to use Accesspoints to offload the R2 with maintaining the connections etc?
- Netduma-FraserMar 06, 2022NetDuma PartnerNot necessarily for that purpose but for WiFi purposes (range/strength) I think they would be better suited than the R2 WiFi
