Dragon791's avatar
Dragon791
Follower
Sep 21, 2020
Looking for best equipment for use with 1Gb internet from Suddenlink
Hello, I am currently running a Motorola surfboard modem SB6190 and a netgear R8300 router. Looking to upgrade but was wondering if upgrading to the gaming routers were worth it.  I have suddenlink 1Gb internet which is the best I can do in my area at the moment.
  • It depends on your usage.
    Some would say that yes they help a lot.
    others would say optimize you current setup.
    like if you're currently gaming over wireless, you'll see a benefit to hardwiring in your setup.
    Or if you're using wireless 2.4ghz, to move to 5ghz.
    A lot depends on your current setup, how well its working, and even if you're a hardcore gamer.
  • plemans's avatar
  • What is the kind of ping you're getting to the game you're playing? Do you experience a lot of lag/buffering on devices?
