BanditMask
Mar 07, 2019Aspirant
Losing Internet connection
My new router consistently loses connection to my ISP cable modem.
Logs
[DumaOS] DHCP lease change., Thursday, March 07, 2019 17:15:56 [DumaOS] DHCP new event., Thursday, March 07, 2019 17:15:56...
Mar 08, 2019Guru - Experienced User
What FW is currently loaded?
You might revert to v32
- BanditMaskMar 08, 2019Aspirant
V2.3.2.40
Arris TM1602
- Netduma-FraserMar 09, 2019NetDuma PartnerYou said you set static/reserved IPs was this just for your LAN devices? If so I would recommend doing it in Settings > Internet Setup.
- BanditMaskMar 09, 2019Aspirant
I don't have this option. No access to the modem.
My Nighthawk R6400 never had this issue.
