BanditMask
Mar 07, 2019Aspirant
Losing Internet connection
My new router consistently loses connection to my ISP cable modem.
Logs
[DumaOS] DHCP lease change., Thursday, March 07, 2019 17:15:56 [DumaOS] DHCP new event., Thursday, March 07, 2019 17:15:56...
BanditMask
Mar 08, 2019Aspirant
V2.3.2.40
Arris TM1602
Netduma-Fraser
Mar 09, 2019NetDuma Partner
You said you set static/reserved IPs was this just for your LAN devices? If so I would recommend doing it in Settings > Internet Setup.
- BanditMaskMar 09, 2019Aspirant
I don't have this option. No access to the modem.
My Nighthawk R6400 never had this issue.
- Netduma-FraserMar 09, 2019NetDuma PartnerNot on the modem I mean on the router. Routerlogin.net > Settings > Internet Setup, switch from dynamic to static
Can you do that if the ISP is using DHCP? Wouldn't you need to have them create and assign a static address for that to work?
in any case, I've had them give me a brand new modem of a different manufacturer. Let's see if that changes anything.
