BanditMask
Mar 07, 2019Aspirant
Losing Internet connection
My new router consistently loses connection to my ISP cable modem.
Logs
[DumaOS] DHCP lease change., Thursday, March 07, 2019 17:15:56 [DumaOS] DHCP new event., Thursday, March 07, 2019 17:15:56...
BanditMask
Mar 11, 2019Aspirant
Still losing Internet connection, seems that the intervals in between are longer now though. As to your suggestion, how do I know the static IP to set? According to my ISP only upgrading to a business account has the ability for static IP. Is there another way?
Mar 11, 2019Guru - Experienced User
I would revert to v32 FW version on the XR router.
Most ISPs will not allow for static WAN IPs to be set unless you pay for it or comes on there Business class packages.
Can you try a different ISP modem? Arris TMs are not the greatest.
- Netduma_JackMar 12, 2019NetDuma Partner
Try going back one firmware as Furry suggested, and then see if it's better:
https://kb.netgear.com/000060127/XR500-Firmware-Version-2-3-2-32
- BanditMaskMar 19, 2019Aspirant
Downgrading the firmware seems to have worked. I'll post again if it restarts.
Since it happened with two different modems by different manufacturers, any idea if this might be fixed in a later version?
I'd hate to never be able to update my firmware again.
- FURRYe38Mar 20, 2019Guru - Experienced User
v40 seems to have problems with some users. I presume NG will be making changes.
Your ok to run v32 if it works for you and it provides all you need. You don't always have to update. Unless there maybe some security concerns.
- Netduma_JackMar 20, 2019NetDuma Partner
I expect the version after .40 will be more stable, so you should be ok to upgrade to it once it's released.
