Retired_Member
Jul 30, 2019losing lost of internet on ports
Hi i have the firmware patch v2.3.2.40-c424aww but lately internet stops working on all the ports on the router but the wifi still works what is this about? cheers shaun
Netduma-Fraser
Jul 30, 2019NetDuma Partner
When does this generally occur? Disable instant on/standby modes on your consoles and see if that resolves the issue please once you have got it working again.
- Retired_MemberJul 30, 2019
Hi
this has only just started happening this is for everything wired hue lights arlo base station consoles dont have them on instant on. arlo q which is wifi only works but rest of cameras are down cos they linked to the base station plus netgear seems to have a problem with arris modems well thats me looking from a few posts on here.
here in the u.k we cant pick our own modem which i would like to and use a modem only not a all in one kit.
only way i get anything wired to work is to do a reboot on the router.
- Netduma-FraserJul 30, 2019NetDuma PartnerIs your ISP hub in modem mode or have you got the router in the DMZ? Could you provide a copy of the log file when this next happens please, you can find it in System Information.
