Morty_774_
Jul 04, 2021Aspirant
Lost traffic prioritization after update xr500
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
Jul 04, 2021Guru - Experienced User
Have you tried a factory reset?
Morty_774_
I did reset after firmware update but will try again.
- plemansJul 04, 2021Guru - Experienced User
what firmware version did you update to?
- Morty_774_Jul 04, 2021AspirantV2.3.2.120 duma
- Netduma-FraserJul 06, 2021NetDuma PartnerGive the router a reboot from the interface and then it should load correctly
