Morty_774_
Jul 04, 2021Aspirant
Lost traffic prioritization after update xr500
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
Netduma-Liam
Nov 26, 2021NetDuma Partner
What's the problem you're having exactly? There's nothing out of the ordinary in the logs that you've provided.
CyBer82
Nov 26, 2021Guide
connection problems micro-exposed
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP new event., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP new event., Friday, November 26, 2021 09:54:27
[DumaOS] DHCP new lease allocated., Friday, November 26, 2021 09:54:27
- Netduma-LiamNov 26, 2021NetDuma Partner
If you reserve an IP address for each device that appears to be losing connectivity, does the problem continue and do you still see the same entries in the logs?
- CyBer82Nov 26, 2021Guide
its the same 5time to factory , back flash firmware und install via router
FirmwareversionDumaOS-Version
V2.3.2.130 3.0.202 same Problems
I'll let it go, I'll get back to you with a new log in two hours
all fine now,,,,, after 5th factory downgrad und Update via dumaos install assi.
- CyBer82Nov 30, 2021Guide
the same mess again after a few days what did you do with the 130, I'm really fed up with being an alpha tester. last chance before I send the part back and buy a Cisco
LOG :[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:15:32
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:15:32
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, November 30, 2021 08:35:28
[DumaOS] Theme path does match manifest 'default', Tuesday, November 30, 2021 08:35:28
[DumaOS] The selected theme does not exist: 'default', Tuesday, November 30, 2021 08:35:28
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Tuesday, November 30, 2021 08:37:26
[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:46:21
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:46:22
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:01
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:07
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:07
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:10
[DumaOS] Cloudsync DPI result 'true','nil', Tuesday, November 30, 2021 09:21:12
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:13
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:13
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:13
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:27:27
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:42
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:43
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:44
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:45
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:46
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:47
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:48
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:49
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:50
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:51 - Netduma-LiamNov 30, 2021NetDuma Partner
Do you still have the original IP reservations setup that you did previously? If not, that's likely why you're experiencing the issue again.
no, I didn't, it's the problem with the new firmware version 2.3.2.130, I'll flash back and look
- Netduma-FraserNov 30, 2021NetDuma PartnerWhat's the actual issue you're having with the entries, are you having disconnects? You didn't specifically mention
micro disconnections, I noticed it in steam, thought steam server ;;;; but meanwhile my wife cannot do a home office so the disconnections occur every 5 minutes. after reset it works again for two days without reservations, but you can see that in the log of previous posts
connection problems
- Netduma-FraserNov 30, 2021NetDuma PartnerChange the DHCP start range and put in place the IP reservations for devices, people have reported that helps preventing the disconnections
- CyBer82Dec 07, 2021Guide
not helps !!!
new error
- Netduma-LiamDec 07, 2021NetDuma Partner
Please keep your updates to this thread.
So you're receiving a new problem now, that's not a disconnection?
What did you do in the interface when you noticed this issue? Can you reproduce it every time?
No, the disconnects were there again every 30 seconds, then I logged in via DumaOS, the browser, then it no longer reacts, had to turn the power off 3 times, where I then waited over 1 minute for the last power off then I started the router. After the finished boat and after I had a white light again, I logged in again, then comb this screen !!!!!!! So it is an additional problem, not a new one, so the router works again for two days after a reset without loss of connection !!!!!!
[Log Cleared] Tuesday, December 07, 2021 13:05:36
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:07:38
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:07:38
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:07:50
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:07:50
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:07:50
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:08:09
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:08:09
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:08:09
[DHCP IP: 192.168.1.3] to MAC address ec:0d:e4:8e:bc:70, Tuesday, December 07, 2021 13:08:22
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:08:22
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:08:22
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:09:12
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:09:12
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:09:12
[DumaOS] Theme path does match manifest 'default', Tuesday, December 07, 2021 13:31:18
[DumaOS] The selected theme does not exist: 'default', Tuesday, December 07, 2021 13:31:18
[DumaOS] HTTP download failed with code '404', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI 'HTTP sync failed', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI 'skipping mirror', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI result 'nil','failed to sync', Tuesday, December 07, 2021 13:31:21
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Tuesday, December 07, 2021 13:34:42
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 14:25:19
[DumaOS] DHCP new event., Tuesday, December 07, 2021 14:25:19
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 14:25:19
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 14:26:03
[DumaOS] DHCP new event., Tuesday, December 07, 2021 14:26:03
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 14:26:03 - Netduma-FraserDec 07, 2021NetDuma PartnerThe error looks to be because you have an Adblocker enabled on the web browser, disable it then refresh the page. The log there indicates you didn't adjust the DHCP start range as suggested, please change it to start at .50, then give devices IP reservations between .2 and .49 and it will be more effective and should hopefully limit the disconnections.
- paul5680Dec 07, 2021AspirantHow do I fix that
- Netduma-LiamDec 08, 2021NetDuma Partner
paul5680 To install a new firmware, you can follow this guide: https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
Please first downgrade to this firmware: https://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.114.zip
Then re-upgrade to the new one afterwards.
- CyBer82Dec 08, 2021Guide
thx , search self for the error and now i found it
SecurityError: Permission denied to access property "dispatchEvent" on cross-origin object - url: moz-extension://f985b107-bcb9-45d4-95c4-b1bb39443725/js/inject.js - line: 65 - column: 0 - error: SecurityError: Permission denied to access property "dispatchEvent" on cross-origin object
https://addons.mozilla.org/de/firefox/addon/google-consent/
and i fix the ports betwin 2-49 now no disconnects, But it is not a permanent solution, so we work even faster with home office that we USERS and those who push the money down your throat are also satisfied.
the whole problem began with the 130FW where every few hours people open thread where they disconnects
Weird, is not it ?
- Netduma-LiamDec 09, 2021NetDuma Partner
Where did you get this error initially? I'm not sure I understand.
We get that reserving IPs is not a permanent fix, it's just a workaround until the DHCP error is resolved.
If you have any further questions, please do let us know.
