Morty_774_
Jul 04, 2021Aspirant
Lost traffic prioritization after update xr500
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
CyBer82
Nov 26, 2021Guide
connection problems micro-exposed
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP new event., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP new event., Friday, November 26, 2021 09:54:27
[DumaOS] DHCP new lease allocated., Friday, November 26, 2021 09:54:27
Netduma-Liam
Nov 26, 2021NetDuma Partner
If you reserve an IP address for each device that appears to be losing connectivity, does the problem continue and do you still see the same entries in the logs?
- CyBer82Nov 26, 2021Guide
its the same 5time to factory , back flash firmware und install via router
FirmwareversionDumaOS-Version
V2.3.2.130 3.0.202 same Problems
I'll let it go, I'll get back to you with a new log in two hours
all fine now,,,,, after 5th factory downgrad und Update via dumaos install assi.
- CyBer82Nov 30, 2021Guide
the same mess again after a few days what did you do with the 130, I'm really fed up with being an alpha tester. last chance before I send the part back and buy a Cisco
LOG :[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:15:32
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:15:32
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Tuesday, November 30, 2021 08:35:28
[DumaOS] Theme path does match manifest 'default', Tuesday, November 30, 2021 08:35:28
[DumaOS] The selected theme does not exist: 'default', Tuesday, November 30, 2021 08:35:28
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Tuesday, November 30, 2021 08:37:26
[DumaOS] DHCP new event., Tuesday, November 30, 2021 08:46:21
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 08:46:22
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:15:52
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:20:51
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:01
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:07
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:07
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:10
[DumaOS] Cloudsync DPI result 'true','nil', Tuesday, November 30, 2021 09:21:12
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Tuesday, November 30, 2021 09:21:13
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Tuesday, November 30, 2021 09:21:13
[DumaOS] recovering state com.netdumasoftware.dpiclass, Tuesday, November 30, 2021 09:21:13
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:21:33
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:01
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:22:04
[DumaOS] DHCP new event., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:26:36
[DumaOS] DHCP lease change., Tuesday, November 30, 2021 09:27:27
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:42
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:43
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:44
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:45
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:46
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:47
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:48
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:49
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:50
[DoS Attack: ACK Scan] from source: 146.66.155.54, port 27028, Tuesday, November 30, 2021 09:35:51 - Netduma-LiamNov 30, 2021NetDuma Partner
Do you still have the original IP reservations setup that you did previously? If not, that's likely why you're experiencing the issue again.
no, I didn't, it's the problem with the new firmware version 2.3.2.130, I'll flash back and look
- Netduma-FraserNov 30, 2021NetDuma PartnerWhat's the actual issue you're having with the entries, are you having disconnects? You didn't specifically mention
micro disconnections, I noticed it in steam, thought steam server ;;;; but meanwhile my wife cannot do a home office so the disconnections occur every 5 minutes. after reset it works again for two days without reservations, but you can see that in the log of previous posts
- paul5680Dec 07, 2021AspirantHow do I fix that
- Netduma-LiamDec 08, 2021NetDuma Partner
paul5680 To install a new firmware, you can follow this guide: https://kb.netgear.com/23442/How-do-I-update-the-firmware-on-my-NETGEAR-router-with-a-web-browser
Please first downgrade to this firmware: https://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.114.zip
Then re-upgrade to the new one afterwards.
