Morty_774_
Jul 04, 2021Aspirant
Lost traffic prioritization after update xr500
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
Netduma-Liam
Nov 25, 2021NetDuma Partner
You can ignore those entries in the logs, they're mainly there for devs to look at if there's a problem. While the entries you're seeing may seem sinister, they're nothing to worry about.
Are you still having issues with Traffic Prioritisation loading? Can you send a screenshot of what you're seeing now?
paul5680
Nov 26, 2021Aspirant
I can take a picture when I get off from work at 6am Saturday morning. When I'm in QOS the traffic just spins nothing load under traffic prioritizing tab. Now my DNS says 8.8.8.8
- Netduma-FraserNov 27, 2021NetDuma PartnerI think you'll need to downgrade then upgrade again and don't do a reset and it should load
