Morty_774_
Jul 04, 2021Aspirant
Lost traffic prioritization after update xr500
I updated my router yesterday and since then I’ve lost the traffic prioritization box on the QOS page? Any ideas why? Thanks.
CyBer82
Nov 26, 2021Guide
connection problems micro-exposed
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:43
[DumaOS] DHCP new event., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:46:48
[DumaOS] DHCP new event., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:49:56
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:12
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:26
[DumaOS] DHCP new event., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:50:52
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:05
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:28
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:34
[DumaOS] DHCP new event., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP lease change., Friday, November 26, 2021 09:53:42
[DumaOS] DHCP new event., Friday, November 26, 2021 09:54:27
[DumaOS] DHCP new lease allocated., Friday, November 26, 2021 09:54:27
CyBer82
Nov 30, 2021Guide
connection problems
- Netduma-FraserNov 30, 2021NetDuma PartnerChange the DHCP start range and put in place the IP reservations for devices, people have reported that helps preventing the disconnections
- CyBer82Dec 07, 2021Guide
not helps !!!
new error
- Netduma-LiamDec 07, 2021NetDuma Partner
Please keep your updates to this thread.
So you're receiving a new problem now, that's not a disconnection?
What did you do in the interface when you noticed this issue? Can you reproduce it every time?
No, the disconnects were there again every 30 seconds, then I logged in via DumaOS, the browser, then it no longer reacts, had to turn the power off 3 times, where I then waited over 1 minute for the last power off then I started the router. After the finished boat and after I had a white light again, I logged in again, then comb this screen !!!!!!! So it is an additional problem, not a new one, so the router works again for two days after a reset without loss of connection !!!!!!
[Log Cleared] Tuesday, December 07, 2021 13:05:36
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:07:38
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:07:38
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:07:50
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:07:50
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:07:50
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:08:09
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:08:09
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:08:09
[DHCP IP: 192.168.1.3] to MAC address ec:0d:e4:8e:bc:70, Tuesday, December 07, 2021 13:08:22
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:08:22
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:08:22
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 13:09:12
[DumaOS] DHCP new event., Tuesday, December 07, 2021 13:09:12
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 13:09:12
[DumaOS] Theme path does match manifest 'default', Tuesday, December 07, 2021 13:31:18
[DumaOS] The selected theme does not exist: 'default', Tuesday, December 07, 2021 13:31:18
[DumaOS] HTTP download failed with code '404', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI 'HTTP sync failed', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI 'skipping mirror', Tuesday, December 07, 2021 13:31:21
[DumaOS] Cloudsync DPI result 'nil','failed to sync', Tuesday, December 07, 2021 13:31:21
[DoS Attack: SYN/ACK Scan] from source: 95.217.31.46, port 443, Tuesday, December 07, 2021 13:34:42
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 14:25:19
[DumaOS] DHCP new event., Tuesday, December 07, 2021 14:25:19
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 14:25:19
[DHCP IP: 192.168.1.2] to MAC address a8:5e:45:cf:64:bf, Tuesday, December 07, 2021 14:26:03
[DumaOS] DHCP new event., Tuesday, December 07, 2021 14:26:03
[DumaOS] DHCP lease change., Tuesday, December 07, 2021 14:26:03 - Netduma-FraserDec 07, 2021NetDuma PartnerThe error looks to be because you have an Adblocker enabled on the web browser, disable it then refresh the page. The log there indicates you didn't adjust the DHCP start range as suggested, please change it to start at .50, then give devices IP reservations between .2 and .49 and it will be more effective and should hopefully limit the disconnections.
- CyBer82Dec 09, 2021Guide
thx , search self for the error and now i found it
SecurityError: Permission denied to access property "dispatchEvent" on cross-origin object - url: moz-extension://f985b107-bcb9-45d4-95c4-b1bb39443725/js/inject.js - line: 65 - column: 0 - error: SecurityError: Permission denied to access property "dispatchEvent" on cross-origin object
https://addons.mozilla.org/de/firefox/addon/google-consent/
and i fix the ports betwin 2-49 now no disconnects, But it is not a permanent solution, so we work even faster with home office that we USERS and those who push the money down your throat are also satisfied.
the whole problem began with the 130FW where every few hours people open thread where they disconnects
Weird, is not it ?
- Netduma-LiamDec 09, 2021NetDuma Partner
Where did you get this error initially? I'm not sure I understand.
We get that reserving IPs is not a permanent fix, it's just a workaround until the DHCP error is resolved.
If you have any further questions, please do let us know.
