Jrooker
May 07, 2020Aspirant
Low Speeds - Nighthawk R7960P
I purchased the Nighthawk X6S R7960P about six months ago and it worked great in my old apartment with a download speed of 120mbps. I just purchased a house that allowed me to get comcast 1000mbps do...
May 07, 2020Guru - Experienced User
A wired PC connected to the router should result in seeing near 900Mpbs using Ooklas installable speed test app.
Wireless may max out at around 300-500Mpbs depending upon conditions, signal, noise and wireless mobile device design and support. Not all wifi devices will see higher speeds.
Please continue to post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
