JohnWalkden
Aug 23, 2020Aspirant
Low speeds from nighthawk XR 500
I’ll try to keep this as simple as possible. I have virgin coming in to a V3 hub and have a 350 meg package. If I connect the nighthawk direct and use the V3 as a modem I get good speed. Unfort...
Aug 25, 2020Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
- Netduma-FraserAug 26, 2020NetDuma PartnerIf you plug directly into the XR what speeds do you get wired? Also if you plug directly into the powerline adapter what speeds do you get on a PC?
