JohnWalkden
Aug 23, 2020Aspirant
Low speeds from nighthawk XR 500
I’ll try to keep this as simple as possible. I have virgin coming in to a V3 hub and have a 350 meg package. If I connect the nighthawk direct and use the V3 as a modem I get good speed. Unfort...
Aug 26, 2020Guru - Experienced User
Any progress on this?
Unfortunately this means it all sits in the living room.
So I want to move it.
I have the V3 on modern & router mode, then cat 7 to a power line plug, then exits at another power line plug, then into the internet (yellow) port of the nighthawk.
So the nighthawk is just extending the signal, however if I speed check it (via app) it’s down to 60 meg.
Any ideas would be appreciated.
Just want a good WiFi at the back of the house.
