ReklessKing
Feb 26, 2024Aspirant
Low speeds high ping ethernet and wifi
I pay for 1gig download through spectrum, recently got all cable lines redug cause was high latency issues and it was busted. Everything was tested all the way up to the cat6 cable from modem to rout...
Feb 26, 2024Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed?
