ReklessKing
Feb 26, 2024Aspirant
Low speeds high ping ethernet and wifi
I pay for 1gig download through spectrum, recently got all cable lines redug cause was high latency issues and it was busted. Everything was tested all the way up to the cat6 cable from modem to rout...
ReklessKing
Mar 15, 2024Aspirant
Apologies just saw this and i had sent last message in caps on accident my bad. I do a lot of times have congestion control set to auto but say im on ethernet would it be slighty different on speeds. I get high ping in my games which dont understand why even when im getting half speeds cause of the congestion control, i know speeds dont play a huge part into your ping but still.
Netduma-Fraser
Mar 15, 2024NetDuma Partner
Ping Heatmap indicates that's the lowest ping to servers that you're able to attain, if you connect directly to your modem what pings do you get to games? That will give you an indication of if it can be lowered any further
