Andriuzz
Feb 27, 2023Aspirant
Mac filtering issue XR1000
Hello, I'm trying to connect a new Epson printer via WiFi to the network and it seems that every 1 min it gets disconnected for a few seconds and comes back up after. I managed to get an error ...
- Feb 27, 2023Are you using Smart Connect for WiFi? If so I suspect that is actually the issue. In which case disable Smart Connect and connect it specifically to 2.4GHz, does it work correctly then?
Netduma-Fraser
Feb 27, 2023NetDuma Partner
