Andriuzz's avatar
Andriuzz
Mac filtering issue XR1000
Hello,   I'm trying to connect a new Epson printer via WiFi to the network and it seems that every 1 min it gets disconnected for a few seconds and comes back up after.  I managed to get an error ...
  • Netduma-Fraser's avatar
    Feb 27, 2023
    Are you using Smart Connect for WiFi? If so I suspect that is actually the issue. In which case disable Smart Connect and connect it specifically to 2.4GHz, does it work correctly then?
