timblack
Mar 01, 2021Tutor
Macbook Pro and Air won't connect to Extender
I have an EX7500/AC2200 Tri-band extender set up on the 2.4 and 5 ghz bands. It is ending out a good strong signal on both frequencies. Netgear firmware was updated last week. However, for some reas...
Mar 01, 2021Guru - Experienced User
might also have better luck posting in the range extender forum versus the gaming forum for dumaos
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
