carchd
Mar 09, 2018Aspirant
MACBOOK PRO Not Showing in Device Manager DumaOS
Hi, All of my other nodes on the network appear fine, phones, computers, gaming consoles etc. My Macbook does not. The only thing that is different about my Macbook is that it has a VPN client on...
Netduma-Fraser
Mar 09, 2018NetDuma Partner
Hi carchd, do you see any nameless/unnamed devices on the Device Manager? If so then that is very likely the Macbook, check the Macbooks IP address or MAC address and then check that again the Device Manager device. Then you can rename it.
If you don't have that at all, turn off the VPN on the Macbook do you then see it on the Device Manager?
carchd
- Discoverable on WiFi
- Hard Wired, VPN client off, still nothing though.
- Netduma-FraserMar 09, 2018NetDuma PartnerCan you use it via WiFi? I'd highly recommend calling Netgear as they should be able to resolve it quickly.
