Billybudz420
Apr 16, 2020Apprentice
Major issues
I'm having major issues. wifi keeps dropping or devices connected say no internet. sometimes 5ghz doesn't work not allowing anytjing to connect. The other issue is port forwarding for xbox... its does...
Netduma-Fraser
Apr 16, 2020NetDuma Partner
Which router are you using? Are you using Smart Connect? How are you determining the NAT status? What is your physical setup?
- Billybudz420Apr 16, 2020ApprenticeI'm using the xr500.... I using my Xbox it's strict nat and will not change for port to the ones I forward. That connection is wired and the wifi has smart connect turned of.... set up is modem to router..... comcast gig speed things have been working..... devices connect tonwifi but say no internet yet the xbox still works
- Netduma-FraserApr 21, 2020NetDuma PartnerWhat is the comcast modem? Does it provide WiFi or is it a pure modem? If you give some of the WiFi devices reserved IPs in LAN Settings does that stop them disconnecting?
