bobbydigital00
Oct 27, 2022Apprentice
Managed Switch GS308T & Nighthawk XR1000 - No Access From Different Subnet
Hello World, I have a quick question. I have separate networks for my nighthawk router and for my managed switch. I'm using PFsense as my firewall and everything is directly connected behind the ...
schumaku
Oct 28, 2022Guru - Experienced User
Reads like a basic default routing issue. All devices on each subnet must have the primary router (the PFsense firewall) defined as the default gateway.
The XR1000 is a NAT router, not a fully fledged IP router - difficult to reach the LAN IP subnet from the WAN/Internet port.
bobbydigital00
Oct 28, 2022Apprentice
Hello schumaku
Routing isn't the issue. I am reaching the router. However it's returning certificate error, "404 Not Found
This server does not support the operation requested by your client."
This error only happens when I'm on a different network. Not sure why I would get cert errors based on the IP address.
