bobbydigital00
Oct 27, 2022Apprentice
Managed Switch GS308T & Nighthawk XR1000 - No Access From Different Subnet
Hello World, I have a quick question. I have separate networks for my nighthawk router and for my managed switch. I'm using PFsense as my firewall and everything is directly connected behind the ...
bobbydigital00
Oct 28, 2022Apprentice
Hello schumaku
Routing isn't the issue. I am reaching the router. However it's returning certificate error, "404 Not Found
This server does not support the operation requested by your client."
This error only happens when I'm on a different network. Not sure why I would get cert errors based on the IP address.
schumaku
Oct 28, 2022Guru - Experienced User
Ok, so it's just the limited information provided about this network configuration probably. A little bit more details would be useful here.
Here again, make a drawing what and is connected, which router adapters are in use, which IP subnets are involved, what IP addresses are configured on the router, ...
...how and on what interface, IP address and adapter you reach that router...
