mkeballa
Sep 23, 2020Aspirant
Massive internet speed drop from router to computer
Netgear CM700 Modem XR500 nighthawk router Having massive speed drops, internet from modem direct to computer 115mbps, when running through router hardwired into computer only getting 4mbps, cal...
Netduma-Fraser
Sep 23, 2020NetDuma Partner
Have you enabled QoS at all? Is that through a wired test you're receiving the low speeds? Do you get higher speeds when using WiFi?
- mkeballaSep 23, 2020Aspirant
I have used Qos on and with it off seleted to never but speeds are still very slow, I have run a speed test on WIFI and the wifi is getting 100mbps but the wired connnection only 4mbps
- Netduma-FraserSep 23, 2020NetDuma PartnerCould you provide a screenshot of the Device Manager table view please?
here is the device manager screen
