mkeballa
Sep 23, 2020Aspirant
Massive internet speed drop from router to computer
Netgear CM700 Modem XR500 nighthawk router Having massive speed drops, internet from modem direct to computer 115mbps, when running through router hardwired into computer only getting 4mbps, cal...
Netduma-Fraser
Sep 23, 2020NetDuma Partner
Have you enabled QoS at all? Is that through a wired test you're receiving the low speeds? Do you get higher speeds when using WiFi?
mkeballa
I have used Qos on and with it off seleted to never but speeds are still very slow, I have run a speed test on WIFI and the wifi is getting 100mbps but the wired connnection only 4mbps
- Netduma-FraserSep 23, 2020NetDuma PartnerCould you provide a screenshot of the Device Manager table view please?
- mkeballaSep 23, 2020Aspirant
here is the device manager screen
PROBLEM FINALLY SOLVED.
After hours of trying to figure out what my issue was.
Windows+X
Device manager
network adapters right click to properties
Advanced
Large send offload V2 (IPv4) disabled
Large send offload V2 (IPv6) disabled
Same screen scrolled down to Speed and Duplex
set value to 1.0 GB FULL DUPLEX
I am running 110mbps now with router. Router was showing 100mbps HALF duplex in the negear router setup. Now issue is fixed and running perfect.
