HunterHarden
Jul 11, 2019Tutor
Matchmaking Destiny 2
Does anyone know how to lockdown matchmaking to your LAN so you don’t have to private match? I have an XR500 Pro Gaming and I want to only matchmake with friends on my WiFi?
Netduma-Fraser
Jul 14, 2019NetDuma Partner
Not sure I understand, you want to go into matchmaking but just team with & play against your friends who are connected to your WiFi? I suppose in theory if you had all devices added to the Geo-Filter with radius in the ocean for example but you can only add 4 devices so you are limited there.
HunterHarden
Jul 14, 2019Tutor
Thanks for the reply! Destiny 2 does 2 host leaders so having 4 is more than enough. Thanks. 👍
